PC-DIO-96PnP Windows 98 Install Issue
I have ISA based PC-DIO-96PnP Card. The card gets detected in windows but the driver doesn't get configured properly. The property dialog box of the card reads:
"The device is not working properly because the BIOS in the device is reporting the resources for the device incorrectly (Code 9)"
I searched NI support. The issue is listed in document having document ID 1CHAPPG0. The solution is to get my card's firmware upgraded.
The problem now is where should I get the firmware for the card and how to upgarde the card's firmware
(2,806 Views)
Thankyou for posting to the National Instruments Discussion Forums.
You will have to send your card into National Instruments for repair. You can contact any National Instruments Applications Engineer here: www.ni.com/support
They will be more than happy to help you out.
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(2,793 Views)
