Multifunction DAQ
Ni USB 8451 Cannot work
Hi All,
My Ni USB 8451 cannot work suddently, checked in PC device manager, it was change to "NI USB-8451 firmware loader ", when it is normally, the device name is "Ni USB-8451"
(2,086 Views)
How about on another computer? - would help to identify if the instrument was bricked somehow or just your computer was messed up.
Try resetting NI MAX too,
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8awSAC&l=en-US
Santhosh
Soliton Technologies
(2,048 Views)
Had tried with different PC,and tried different Ni USB 8451 with same PC, confirmed only this unit failed in this.
(2,045 Views)
Had reset the NI MAX, but it didn't solve the issue, I guess the firmware was lost.
(2,038 Views)
Best to reach out to NI Support https://www.ni.com/my-support/s/service-requests
It may be possible, you could recover it or worst case, you need to buy a new one.
Santhosh
(2,035 Views)
Hi, I have the same problem. have you solved it?thanks.
(1,649 Views)
I replaced the it by NEW Ni USB 8451.
(1,642 Views)
