Multifunction DAQ
取消
顯示結果
搜尋替代
您的意思是:
Negative current values while voltage measurements are positive
Hi, I am using DAQ tool for power measurements of CPU power domain. I recorded the current and voltage samples while running the applications. What I observed that sometimes I am getting negative current values while voltage values are positive. Are this negative current values due to noise? Regards, D.verma
0 積分
1 條訊息(共 3 條)
3,296 檢視
Hi, Voltage values are positive because it is dc voltage but could not figure out the negative current values which are coming some times. Is it possibility because of noise? Regards, D.verma
0 積分
2 條訊息(共 3 條)
3,292 檢視
Please post a schematic of your setup.
Greetings from Germany
Henrik
LV since v3.1
0 積分
3 條訊息(共 3 條)
3,283 檢視
