08-11-2010 12:23 PM
@Iandol wrote:
sadly LabJack only make USB devices
We also do Ethernet, and have a couple new interfaces in the works, but we only make external devices and no internal cards.
08-12-2010 02:18 PM
Just to close the loop here, NI-PAL is a shared library used by other drivers. Currently NI-PAL does not support OS X 10.6 K64, so as sth mentioned it's expected you'll be getting these errors. We're currently working on getting support in this library, and once that happens we'll look at providing support with other drivers as well.
08-13-2010 09:31 AM
08-16-2010 10:39 AM
Announcing support for OS X 10.6 (Snow Leopard) available immediately for download.
NI-DAQmx Base 3.4 for Mac OS X
Ali M
Applications Engineer
08-16-2010 11:41 AM
Ali, didn't Joe just announce this two weeks ago in this thread? Is this a different version?
08-16-2010 05:58 PM
I believe this is the version that was announced.
I've not yet had a chance to test it with my USB DAQ hardware.
NI is amazingly fast, too!
It only took them a year from the introduction of Snow Leopard to support it!
08-17-2010 09:14 AM
Correct, its the announced version. Thanks 😉
Ali M
01-04-2011 08:02 AM
Does NI-PAL yet support OSX 10.6K64? It's 2011 and I've been waiting a long time.
01-04-2011 11:55 AM
No unfortunately. I have installed the latest VISA. As you can see there are only two architectures supported by the nipalk driver. ppc and i386
01-28-2011 09:52 AM - edited 01-28-2011 09:58 AM
Just wanted to chime in here. Mac OS X 10.6 *Server* boots to the 64-bit kernel. All kexts have to be 64-bit, but it can run 32-bit applications. When I try to install NI-DAQmx Base, I'm instantly told "NI-DAQmx Base 3.4.0 can't be installed on this computer. Switch to a 32-bit kernel before installing this software."
Any tips on installing on Snow Leopard server? I'm able to install on my Snow Leopard laptop successfully.
I've got a USB-6501 that I'm trying to reach. I would be happy to develop to it using tty if possible but it doesn't seem to be accessible that way.
EDIT: In next post I mention how I am mistaken here.
