02-23-2006 11:36 AM
02-24-2006 01:25 PM
02-25-2006 10:29 AM
03-28-2006 01:38 AM
03-29-2006 03:00 PM
03-31-2006 03:18 AM
04-03-2006 01:24 PM
NIDAQ32.lib
contains in...04-07-2006 04:12 AM
Hello friend:
I have a try with nidaq32b.lib ,but the same questions. I think NIDAQ8.0 does not support the "nidaq32b.lib". Am I right?
04-11-2006 09:51 PM
Hello everybody:
There is a question about daqmx8.0 programming with boland c++ builder !
The lib file "daqmx.lib" is always not fit for bcb! why?
thanks for your attention!
04-12-2006 06:45 PM
Wuducookie,
DAQmx 8.0 does not officially support, nor has been tested with Borland C++. So though it may be possible to use some of the techniques mentioned in previous posts to get it to work, it is not something that DAQmx 8.0 was designed to do. Is there any particular reason that you need to use Borland C++? There may be some other options that would suit your needs. Let us know what your end goal is, and what you need from your programming environment and we may be able to offer some other options for you. Regards,
