Multifunction DAQ
NI6133 with extern Start Trigger - Error -200625
I want to start an analog input with extern start trigger on my Multifunction DAQ 6133.
I have connected the right analog input channel to the trigger signal (all analog input channels are assisted for Starttrigger as it is in the manual), but I always get the errormessage -200625 (DAQmxErrorInvalidAnalogTrigSrc).
What must I do to avoid this error?Smiley Sad
(2,841 Views)
he error-message tells you that you have choosen the wrong source for the analog trigger. Which channel did you choose? Maybe you could attach an example?
(2,828 Views)
Thanks, but i solved this Problem by myself. It was the wrong Hardware configuration.
(2,825 Views)
