NI-Scope Functionality?
Hello All
New NI-SCOPE user.  Does NI-SCOPE offer th functionality to automatically record wave forms (create references) and data (values for excel) on a pre-defined interval?
If it does not, is there software that can?
(4,876 Views)
Hi digigdawg,
The NI-VISA is a driver for our scopes and digitizers. While it does offer the soft front panel that looks and acts like a normal scope interface, you cannot set up recording or automatic measurements with it.
In order to save the measurements, I would recommend using LabVIEW or LabWindows/CVI with using the NI-SCOPE drivers to save the data as you can also analyze your data at the same time.
Justin M.
Applications Engineering
(4,834 Views)
Respected Sir,
                 Is NI-Scope is Compatible with cRIO9063?
(3,471 Views)
Hey VishnuEdara,
NI-SCOPE is not compatible with the cRIO-9063. The cRIO-9063 is a controller with the NI Linux Real-Time OS installed, but NI-SCOPE is only compatible with Windows. You can see this information in the README for NI-SCOPE (http://download.ni.com/support/softlib//high_speed_digitizers/niscope/windows/16.0/readme.htm).
Will
(3,461 Views)
