Multifunction DAQ
NI SCB-68A Setup Help
Hello, I have a NI SCB-68A, this multifunction cable: http://www.ni.com/en-us/support/model.shc68-68-epm.html , and an encoder that I would like to find the angular speed of. However, I do not have a way to connect the white end of the multifunction cable to my computer. Am I missing something necessary to set this up?
(3,429 Views)
Accepted by topic author jaredhaley
Hi jaredhaley,
What DAQ device are you using? This cable is supposed to connect to a PCI/e card such as the PCIe-6321.
The PCI/e card plugs in to your computer PCI/e slot and it gives you the I/O that you need for this cable.
Best,
Ben
Technical Support Engineer
(3,388 Views)
I don't think I have a PCI/e input on my computer but since I'm on vacation I'll have to check when I get back. I guess I also do not have a DAQ device, could you provide an example of what one of those would be? When initially setting up the project I figured that was the SCB device. Thanks
(3,359 Views)
Figured it out, thank you!
(3,337 Views)
