05-07-2012 06:06 AM
How do I link a Physical Channel to a NI USB-6009 DAQ device to acquire Analog Input Voltage from a C Cell Battery?
I am trying to do this with a MacBook Pro I have downloaded and installed the NI-DAQmx Base 3.5 driver software and my device is recogonized as Dev1.
05-07-2012 10:14 AM
I do not have any DAQ devices (at least none recognized by DAQmx Base) so I cannot check. You may need to type in the name.
Lynn
05-08-2012 03:11 PM
Hi rob546109,
If your device is recognized then you should be all set to input the appropriate physical channel to the DAQmx Base Create Channel VI. This can be done be placing a constant or control to the Physical Channel input on that VI. A drop-down menu will be available for you to choose which device and port you wish to associate with the task. I have included some links in this message that will direct you towards some examples that will give you some direction on how to acomplish this.
https://decibel.ni.com/content/docs/DOC-3882
http://digital.ni.com/public.nsf/allkb/BEA8C88ED8B09AF286256ED0004544F7?OpenDocument
I hope this information helps. If you have any further questions, please reply to this post.
09-03-2012 07:25 AM - edited 09-03-2012 07:28 AM
