Multifunction DAQ
NI-DAQmx ANSI-C and MFC
Are there any gotchas if I try to interface NI-DAQmx ANSI C code with an MFC C++ (Visual Studio 6) front end application?  If there are gotchas, would putting the DAQ code in a DLL help?
I want to do the straight DAQ - C++ interface rather than Measurement Studio because of funds and lack of time to get familiar with it.
I want to use NI-DAQmx rather than the legacy NI-DAQ because of its better mutli-threading.
Txs for you help
Sergio
Message Edited by ramirez on 05-12-2006 09:37 PM
(2,800 Views)
Sergio,
Here is a Knowledge Base that you may find useful. Hope that helps.
-GDE
(2,772 Views)
hi,
did you found the solution?
for ni-daqmx to work in visual studio 6.0 C++ MFC?
i tried a lot of searching but come out none.
(2,481 Views)
