NI DAQ not working
We have a DAQ with product code NIUSB6251.It's not working and the system connected to it showing "no NI device detected ". The ready indicator is on but active one is not showing any light. Please helpIMG_20220130_190618.jpgIMG_20220130_190415 (1).jpg
Message 1 of 10
(3,374 Views)
Immediate things I would try:
1. Disable the Windows power settings that allow the system to turn off USB hubs.  You will have to do this for each USB hub in the Device Manager.
2. Use a different USB port.
3. Reboot the computer.
GCentral
Message 2 of 10
(3,363 Views)
Most importantly, ensure you've installed a DAQmx driver version that supports your device.
Santhosh
Soliton Technologies
Message 3 of 10
(3,357 Views)
Thankyou for your suggestion, we are working with the same device and system for last one year. It suddenly stopped working, it blinks the active light just once when the system connected to the device is turned on or when we change the USB port , otherwise the active indicator is off  and only ready indicator is on. It happened once earlier but reinstalling the software (the latest version that is compatible with our device) fixed the problem, but this time that also not working.
Message 4 of 10
(3,326 Views)
Were you able to try it on a different computer? a different cable too?
Santhosh
Message 5 of 10
(3,314 Views)
We tried changing cable and system too. Can you tell me the compatible DAQmx driver version with WINDOWS 10 version 2004, right now we have NI DAQ version 21.3
Message 6 of 10
(3,304 Views)
As per the readme, USB-6251 is supported by DAQmx 21.3
Could you please expand the Devices tree item and share a snippet like the one below?
Santhosh
Message 7 of 10
(3,290 Views)
After expending device tree items only have these two options under device and interfaces. Please suggest what we should be doing furtherCapture 3.PNGCapture 2.PNGCapture 1.PNG
Message 8 of 10
(3,285 Views)
Accepted by Madhu100
You have a corrupted database.  You need to reset it.  In MAX, go to Tools->Reset Configuration Data.
GCentral
Message 9 of 10
(3,263 Views)
We have reset the data and it started working, Thankyou for you help.
Message 10 of 10
(3,254 Views)
