NI 9265 combining two outputs for a 0-40mA current range
I have a project that needs a 0-40mA current control and the 9265 is specified to 20mA. Is it possible to combine two of the outputs to increase the current range?
(3,696 Views)
Hi ngh,
Yes you can combine both of them, I recommend you to connect a diode in each output to current protection.
Best,
Carmen C.
(3,677 Views)
Can you show a wiring diagram for combing outputs with the diodes?
Curt
(3,670 Views)
Would using resistors also work?
(3,318 Views)
