NI 9219 ADC Timing
I am using a NI 9219 module on a cDAQ 9174 USB chassis. I need to reconfigure the ADC Timing Mode to High Speed using NI MAX software, but there seems to be a problem.
I found detailed instructions how to do this here: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIVjCAO&l=en-US
Unfortunately, even though this article is only about a year and a half old, the software looks nothing like this now, and does not have a "Configuration" tab. The only option that seems similar is the "Hardware Configuration Utility", but this seems to have almost no options for configuring the hardware. If anything, it just displays some configuration information.
I am using Matlab software to run the cDAQ, so I can't configure the module in LabVIEW; I need to use NI MAX. Does anyone know what I can do? Thanks!
(530 Views)
What's is your NI-DAQmx version? The ADC timing option is still available on my PC with NI-DAQmx 2024 Q3. Are you using the Data Neighborhood?
https://tmesystems.net/
(507 Views)
I am running NI-DAQx 2025 Q1. It looks very similar to yours; thank you for posting a picture.
I see that you are configuring the module ADC timing from inside a task, rather than using the hardware configuration tool. Unfortunately, I cannot create a task at the moment because I am not using NI software to interface with the cDAQ. I am using Matlab.
I guess my next step will be to download the free version of LabVIEW and see if I can make a task then. I'm not sure why they would remove hardware configuration out of the hardware configuration tool...
Thank you for your help!
(503 Views)
Unfortunately, the Matlab Data Acquisition Toolbox does not seem to expose all properties.
I would recommend using ni/nidaqmx-python: A Python API for interacting with NI-DAQmx instead. You can change the ADC timing mode using property ai_adc_timing_mode
You can use nidaqmx-python/examples/analog_in/voltage_acq_int_clk_tdms_logging.py, and then load the TDMS Format Files in MATLAB for data processing.
(492 Views)
ZYOng,
Your suggestion sounds like a good one, unfortunately it will create a new problem for me. My main use of NI cDAQ equipment is for instruction of undergraduates, and we teach them Matlab, not Python. Thus, we would need to restructure a good portion of our curriculum to make this a solid solution for us.
I will add that I have tried a few other options since my original post. NI FlexLogger is simple enough to introduce in class, but it doesn't allow changing the ADC timing mode. I also tried reinstalling the old DAQExpress program. It will allow me to collect at 10 Hz, seemingly bypassing the ADC timing issue. I think I'm stuck at 10 Hz because of something I'm doing wrong in the programming, but I don't intend to pursue this route any further. The software is no longer supported, and so cumbersome that teaching the students Python on the fly would likely be easier.
I'd appreciate other suggestions, but I suspect that there aren't too many other options.
(442 Views)
