Multifunction DAQ
NI 6295: According to the manual the direction of the DI/O can be defined. But how?
I don't use NI-Software, we want to implement the NI 6259 in our own software.
To do so I need to know how to change the direction of the DI/O on startup.
Is it  an initial message that defines the properties of the inputs and outputs?
(3,064 Views)
Accepted by topic author Nitester123
If you don't want to use the NI driver with LabVIEW, LabWindows, C, C++, .NET, etc., then you will have to use the DDK to create your own driver.
On the other hand, if you really meant to say that you will be using a standard programming language with the NI driver (called DAQmx), then look for example programs in C:\Documents and Settings\All Users\Documents\National Instruments\NI-DAQ\Examples. Go to Start>Programs>National Instruments>NI-DAQ to read the DAQmx help.
(3,062 Views)
Thanks for teh fast reply.
We use Visual Studio, so using the DAQmx Driver should be sufficient for our attain aims.
(3,058 Views)
