Multifunction DAQ
NI 6133 Analog Input starting with external Trigger?
I want to start an analog input with extern start trigger on my Multifunction DAQ 6133.
I have connected the right analog input channel to the trigger signal (all analog input channels are assisted for Starttrigger as it is in the manual), but I always get the errormessage -200625 (DAQmxErrorInvalidAnalogTrigSrc).
What must I do to avoid this error?
(3,846 Views)
Please attach your VI or a screenshot at least, so that we can see how you configured your hardware. Which channel have you set asd the source of the trigger, because this seems to be invalid?
(3,829 Views)
Thanks, but i solved this Problem by myself. It was the wrong Hardware configuration.
(3,817 Views)
I have the same problem. Same hardware of 6133 also, with bnc-2110. I want to capture a signal from channel ai0 using an external trigger source which is connected to PFI0. I doubt its my code as it is quite similar to the examples 204226.vi and 200007.vi supplied by the NI website, I always get the same error of Invalid Analog Trigger Source from all 3 VIs.
Anyone?
(3,654 Views)
The 6133 doesn't support analog triggering with a PFI pin as the source.  It only supports analog triggering with an AI channel from the task as a source.  If you want to use PFI as the trigger source, you can only perform digital triggering.  I hope this helps.
(3,623 Views)
