Multifunction DAQ
Driver Support of PCI-6036E
Good morning!
I am trying to install a PCI-6036E with the "NI-DAQmx Version 8.3.1" driver. Windows XP recognizes the hardware and installs the driver, but the device is not recognized by the "Measurement & Automation Explorer". Then I installed the "Traditional NI-DAQ (Legacy) Version 7.4.1" driver and the "Measurement & Automation Explorer" listed the divice. Can I use the PCI-6036E with the new NI-DAQmx driver? And if "yes", how does it work?
Klas Hatje
(5,377 Views)
The PCI-6036E  is supported by DAQmx drivers. See here
Try uninstalling and reinstalling DAQmx on your system
See if your device shows up in MAX, by doing that
(5,361 Views)
I did this several times, but without any success. Do you have another idea?
(5,359 Views)
there are not many possibilities how to manage this problem.
Please try this:
http://forums.ni.com/ni/board/message?board.id=250&message.id=5335&requireLogin=False
If this doesn't help, I would reinstall the complete windows system.
Best Regards
Dippi
(5,331 Views)
Thank you for the support. I reinstalled Windows and now the driver runs properly!
(5,304 Views)
