09-19-2017 07:57 AM
Hi All,
In the datasheet of NI 4472, it is mentioned that the Sampling Rate can be
"102.4 kS/s down to 1.0 kS/s in 190.7 μS/s increments for fs > 51.2 kS/s or 95.37 μS/s increments for fs ≤ 51.2 kS/s"
In this, I am not able to understand if "190.7 uS/s" is 190.7 uSamples/Second or 190.7 uSecond/Sample. If we consider the first case, we cannot have micro samples but the terminology is confusing.
Kindly give your suggestions
Thanks in Advance,
Sree Ranjani
解決済! 解決策の投稿を見る。
09-19-2017 09:33 AM
I am pretty sure those are supposed to be microseconds/Sample. Which gives ~5.2kS/s increments when fs > 51.2kS/s.
09-20-2017 04:42 AM
Thank You crossrulz,
If we use the PXI backplane clock a the reference clock for DAQ device, will we be able to get better resolution? If so what will be the resolution? How to calculate the resolution?
09-20-2017 06:24 AM
No. That will just give you a more accurate base clock, resulting in less jitter.
