Multifunction DAQ
My new 6062 DAQcard ret is unrecognized by the E series Calibrate VI. I get error 10840 "...the board is not a National Instr...". The board works finr running other VI's and workd fine in MAX. Anyone know what iswrong?
Why is my new DAQcard 6062E not recognized by the E Series Calibragte VI? I'm getting error 10840.
(2,907 Views)
Hello Highway-Star,
Thank you for contacting National Instruments.
This error is most commonly associated with an incorrect device number. Please see this KB and the image attached below for information on how to properly use this VI:
http://digital.ni.com/public.nsf/websearch/51A15DD0CE9491B586256A1D00631940?OpenDocument
Please reply to this post if this information does not resolve your issue.
Bill B
(2,907 Views)
Thanks Bill,
I already figured it out. That was it. The task ID was set to zero and the device number was actually 1.
Do you know when DAQmx is going to support the SC2345. I would like to use mx on my system but DAQmx 7.2 doesn't support the 2345 just the 2350. Any idea when this will happen?
(2,907 Views)
The SC-2345 is supported in all versions NI-DAQmx. Its configuration is a bit different than with Traditional NI-DAQ however. Right-click on NI-DAQmx Devices and choose "Create New NI-DAQmx Device >> NI-DAQmx SCC Connector Block >> SC-2345". The SC-2345 is then listed as a seperate device which you can associate with your DAQCard. The SC-2350 is a new SC Carrier that is only supported in version 7.2 of NI-DAQmx.
Allen P.
(2,907 Views)
