Multifunction DAQ
LabView install at every boot
Ever since I installed NiDAQ 7.2 to complement my LabWindows 6.0 setup, every time I boot my
machine I get the installer for "NI LabVIEW Run-Time Engine 7.0" popup that asks me to insert the
CD to a path to lvruntimeeng.msi
I never installed anything labview related. How do I get rid of this message ? Whether I point it
to a valid directory or not (press Cancel), I get asked 3 times.
I have no idea where this is started from: I cannot find the handle for this popup in the system:
I looked in the usual startup places ([Start][Programs][Startup], Registry/Run menus...)
Guillaume Dargaud
http://www.gdargaud.net/
"AI: anything a computer can't do yet."
(2,576 Views)
Hi Guillaume,
Measurement & Automation Explorer uses the LabVIEW Runtime Engine. Normally, it is installed automatically with the NI-DAQ 7.2 installer. However, you can also install it manually and this will solve the problem. You can download the LabVIEW Run-time Engine from our Drivers and Updates page. In the search area, choose LabVIEW as the product line, LabVIEW Run-time Engine as the software, 7.0 as your version, and your operating system to find the right version.
Allen P.
(2,576 Views)
> href="http://digital.ni.com/softlib.nsf/MainPage?ReadForm&node=132010_US">Drivers
> and Updates
Thank you.
Guillaume Dargaud
"I sleep better at night knowing that scientists can clone sheep." - Jeff Ayers.
(2,576 Views)
