Multifunction DAQ
Multiple channel string format
I'm developing an application in VB6 for a USB-6009.  I need to sample analog channels 0,1,2,4 at a certain range (+10/-10) with respect to ground, but also channel 3-7 differentially at a different range (+1/-1).  Can I specify this with a channel string or do I have to create multiple virtual channels in the program?  The bundled example for analog input (Acq-Int Clk.frm) allows you to specify a channel string but I'm pretty sure whichever I enter it's sampling differentially.
Thanks,  Peter Chabot
(3,017 Views)
You will have to use multiple create channel function calls.  You can use one create channel function for the channels you want RSE, set your range to +-10V and use a channel string like this: "DevX/ai0:2, DevX/ai4".  Use another create channel function for the channel you want to measure differentially.  Set the range to +-1V, use the channel string: "DevX/ai3".  Use the same task name for both functions to add all channels to the same task.
-Alan A.
(3,003 Views)
