04-18-2006 12:02 PM
04-19-2006 10:39 AM
You will have to use multiple create channel function calls. You can use one create channel function for the channels you want RSE, set your range to +-10V and use a channel string like this: "DevX/ai0:2, DevX/ai4". Use another create channel function for the channel you want to measure differentially. Set the range to +-1V, use the channel string: "DevX/ai3". Use the same task name for both functions to add all channels to the same task.
-Alan A.
