‎04-23-2008 06:08 PM
Hi there,
I want to acquire 2 to 4 signals incoming from photo diodes, I am interested
only in the maximum amplitude of the signal for each, the Laser repetition rate
is at 100Hz. So I was thinking of using a digital signal ,which triggers the
laser, and a delay box to optimize the delay with the corresponding maximum of
amplitude on the diode as read by an oscilloscope and send it as the sample
clock for my Analog input task (for example on the PFI 0). This way each time
the sample clock triggers an analog conversion it reads the maximum of the
diode for each shot ~ 100 shots/s.
It works fine for one channel, but is it possible to use 2 to 4 different
sample clocks each with it s own digital input (ex.: PFI 0, PFI 1 ..) for the
other diodes, since the delays I want to use are not the same for each due to
laser propagation time...
Or is it possible to control the acquisition/conversion delay/trigger between each channel at ~50 nanoseconds precision…so I can delay the acquisition internaly instead of using 2-4 external digital sources..
Any help is welcome ![]()
Regards
Lukasz
‎04-24-2008 05:50 PM
‎04-28-2008 04:18 PM - edited ‎04-28-2008 04:24 PM
‎04-29-2008 04:43 PM
‎04-29-2008 04:53 PM
