Monarch Tachometer Sensor
Flip Tek... Thanks for the help, I'm still working on your VI.
Rob F,
Thanks for the help!
The product manual states the output is “TTL compatible pulse”.
Here is where I am at so far.  See attached doc.
Message 11 of 28
(3,693 Views)
I think you just missed the reciprocal. See attachment.
Message Edited by FlipTek on 09-17-2007 02:38 PM
______________
KowdTek
LabVIEW 2009
One Step At A Time, Maybe Two...
Message 12 of 28
(3,692 Views)
Flip Tek,
Thanks for pointing out the missing reciprocal.
Question... are you using the Monarch SPS-5 Series infrared sensor?
After you drag the DAQ Assistant to the Block Diagram what setting are you using for your DAQ Setup?
Here's mine:
Express >> Input >> DAQ Assistant
Create New Express Task Window opens; Acquire Signals >> Counter Input >> Frequency
Supported Physical Channels opens; I select “ctr0”,  It tells me to "Connect Your Signal to (Input Terminal): to PFI1"  This is pins 16 and 1 on the NI 9401.
Configuration Window opens
Setting I select;
Acquisition Mode = Continuous Samples
Samples to Read = 100(default)
Starting Edge = Rising
Measurement Method = 1 Counter (Low Frequency)
Signal Input Range = Max 200 Min 2
Scaled Units Hz.  I click run and 119 appears in the top Measured Values…
Team Stoney
Message 13 of 28
(3,681 Views)
Flip Tek,
I cannot seem to get counter input... any ideas?
Team Stoney
Message 14 of 28
(3,678 Views)
Hello Team Stoney and Flip Tek,
The reciprocal is only needed if your task is measuring the period of your signal.  If your task is measuring frequency, then the driver will automatically make this calculation for you.  If you are using the counters on a cDAQ, then you need to have your module in either slot 5 or 6.
119 (Hz or cycles/second) corresponds to the frequency of the measured waveform.  In order to get RPM just multiple the frequency by 60.  119 (cycles/second) * 60 (seconds/minute) = 7140 (cycles/minute)
Respectfully,
Rob F
Test Engineer
Condition Measurements
Message 15 of 28
(3,655 Views)
Thanks for the follow up Robert.
Team Stoney, I'm using IRS-W that has TTL signal also.
______________
KowdTek
LabVIEW 2009
Message 16 of 28
(3,650 Views)
I'm not sure what version of the Sound and Vibration Toolkit you are using, but the Sound and Vibration Measurements Suite has several order analysis examples that show the user how to synchronize TIO and DSA to acquire vibration and tach signals.  The examples support both PXI and cDAQ (9233/9401).  If you have the Order Analysis Toolkit or are already using the Sound and Vibration Measurement Suite then any example with the name "digital tacho" will work.
Best Regards,
Jeff Tipps
Product Support Engineer
Message 17 of 28
(3,635 Views)
I am using M series USB-6229 DAQ board.i applied the same program ,but i can not getting reading of this vi.any help?
Message 18 of 28
(2,809 Views)
Do you have the same tach sensor?
______________
KowdTek
LabVIEW 2009
Message 19 of 28
(2,802 Views)
i got Monarch spsr-im with ROS tachometer.the output of them would be "TTL compatible Pulse".i used the same VI and configuration for frequency as Rober -F and Team stony ,but i am getting an error .
Message 20 of 28
(2,800 Views)
