Module for pressure sensor
I'm searching for a module that will be able to work well with a TSU series pressure sensor by Seiko-Epson.
The spec is:
Frequency Range: 4K-39KHz
Output voltage: 3.2Vpp clipped sine DC cut
Output load: 600 Ohm
Supply Voltage: 12V
Current consumption: 2mA
Thanks!
Nitsan Gonen
Application Engineer
NI Israel
(4,747 Views)
Well, whoever wrote that datasheet should be shot.  It fails to provide any useful data about how the output signal varies with input pressure.
I am guessing that the output variable is the frequency. I would interpret the datasheet diffferently from the way you did. I see the frequency changing by a maximum of 4 kHz from the 39 kHz nominal as opposed to a range from 4 to 39 kHz. Whether up or down or both is not indicated.
Who knows what a "clipped sine DC cut" is???  The DC part makes one think that the signal may be offset from zero in some way, while a peak to peak specification often implies (but does not require) a balanced signal. If the signal varies from 0 to +3.2 V  as a half wave rectified sine, it is very different from a 10 Vpp sine wave which is symmetrically clipped at +/-1.6 V.
And how you measure the signal depends on all those details.
You could purchase an analog input module which can handle the voltage and freqeuncy ranges and then post process whatever signal appears in software to get the frequency and from that the pressure. Or you can figure out what the signal is, buy or build a signal conditioning circuit which prodcues nice clean digital pulses at the same frequency, and then use a counter module to get the frequency.
Lynn
(4,737 Views)
Lynn
Lynn it' a product flyer, not a datasheet.
I like the 'Linearity, after linearization' 🙂
I would guess that any DAQ board with a counter should do the job , maybe a C for decoupling, a diode for a level shift and a resistor....  depending on the actual output (seen on a scope)
BTW with 96kHz samplerate , a voltage divider , decoupling capacitor,  a soundcard with tone detection is also a way to do it 😉 but you would loose the 'linearity' and accuracy since the soundcard oscillator is usually worse.
Greetings from Germany
Henrik
LV since v3.1
(4,727 Views)
Henrik,
I figure that anything claiming to include specifications is a datasheet, especially when it does not include any disclaimer or any reference to more detailed information.
Note that the mechanical drawing is just as bad: it fails to specify the diameter of the mounting holes.
Lynn
(4,705 Views)
