 Bill Choy
			Bill Choy
			10-13-2007 04:44 AM
10-15-2007 02:57 AM
10-16-2007 01:22 PM
Hello Bill,
Thanks for contacting National Instruments.
Justin has made some excellent suggestions to get you started with signal conditioning using real-time. SCXI and SCC both offer signal conditioning solutions compatible with real time that would add on to your existing setup. CompactRIO would require the purchase of additional hardware, but if offers small size and multiple options for signal conditioning built into compatible modules.
If you are looking to purchase any items from NI, it would be best to contact them directly. The technical representatives and applications engineers will be able to help you find the best solution with regards to your current setup and application needs.
Please post back if you have any questions or concerns.
10-16-2007 08:40 PM
10-17-2007 07:40 PM
Hello Bill,
Both the PXI 4070 and PXI 4072 DMMs are capable of high voltage waveform acquisition. Their drivers are compatible with LabVIEW Real Time as well.
If you are interested in purchasing one of these, I would recommend contacting NI directly to ensure that these devices will fit your needs.
10-17-2007 09:09 PM
Hi Browning,
Actually I used 4070 to measure this signal before. However, I have to measure many test points with this signal now so I can't use 4070 because the cost is too expensive and occupy too many PXI slots.
Bill
10-18-2007 08:03 PM
Hello Bill,
If you are able to switch platforms, using CompactRIO with the NI 9221 will allow you to make a high voltage measurement at the 36 kHz.
If you are able to test each of the test points one at a time, there are several PXI switch modules available. If you go to the switches webpage, you can browse through all of the options by categories. These browse options allow for you to narrow the switch down by OS Support, Bus Type, and Maximum Voltage. A switch would allow for you to test multiple test points without the need for multiple digital multimeters or the need to change the wiring.
