Multifunction DAQ
MatLab error loading nidaq32.dll for PCI-6602 in a 64 bit PC
I have to load the nidaq32.dll library for PCI-NI6602 with MatLab; I can do this operation in a 32 bit PC, but when I try to load the library from a 64 bit PC which use Windows 2000 (32 bit) the resulting error is "failed to load library".
Have I make particular settings for a 32 bit O.S if it's installed on 64 bit PC? I imagine that he library is built for 32 bit applications, and the machine works in reality at 32 bit, but why I have problems with loading the nidaq32.dll? Does exist the same library for 64 bit machine?
Thank you
(3,060 Views)
Hi, see following link: Are National Instruments Products Compatible with Windows XP 64-bit for AMD's x86-64 Technology? http://digital.ni.com/public.nsf/websearch/C4EC0C87B6D70AA886256E61006568C8?OpenDocument Actually ni-daq doesn't support 64 bit. Regards AmbuA
(3,050 Views)
