 littlepig
			littlepig
			10-22-2009 09:56 AM
Hi there.
Me and my teacher are trying to install a NI USB-6009 in a snow leopard Max OS. We will use it in LabView2009®. At this moment we already installed the drivers and the application "lsdaq" already detects it: "NI USB-6009: "Dev1" (USB0::0x3923::0x717B::01183702::RAW)"
Moreover, when we click "NI DAQmx base task configuration", in the LabView2009®, we can actually create a task with the device "NI USB-6009: "Dev1" (USB0::0x3923::0x717B::01183702::RAW)". However, after creating a task, like, for instance, "analog input", we can't see the task in the LabView in the button: (Measurement I/O -> DAQmx base - Data acquisition ->) "DAQmx Task Name Constant".
Thank you very much for your time,
littlepig
 Oswald_Branford
			Oswald_Branford
		10-22-2009
		05:43 PM
 - last edited on
		09-08-2025
		02:37 PM
 by
		 Content Cleaner
			Content Cleaner
Hi Littlepig!
This is expected behaviour because you are working on the DAQmx Base version of the driver. You can try to introduce the name of your task directly on the costant or follow the directions on the following link:
http://digital.ni.com/public.nsf/allkb/BEC50958B46CF6B98625707C00504159?OpenDocument
I hope this info helps.
Have a great day!!!
10-23-2009 09:02 AM
 rob546109
			rob546109
			04-28-2012 10:55 AM
Hi Oswald
I was not authorized to open the document you have referenced can you help me?
 rob546109
			rob546109
			04-28-2012 10:57 AM
Hi littlepig,
Were you able to measure a voltage with your NI USB-6009 and display it in LabVIEW?
 johnsold
			johnsold
			04-28-2012 06:41 PM
This thread is >2 years old and neither of the participants has been on the Forums for months or years.
Please start a new thread with a complete description of the problem you are having, what you have tried and what is not working, including any errors you may be getting.
Lynn
 Romain_Duval
			Romain_Duval
		04-30-2012
		04:09 AM
 - last edited on
		09-08-2025
		02:38 PM
 by
		 Content Cleaner
			Content Cleaner
Hi Rob,
John is right. You should create a new topic.
Just in case, I think this is the needed document:
[9/8/25 broken link removed; link no longer available]
regards
Romain DUVAL || RF & Semiconductor Staff System Engineer || CLA || CTA
National Instruments France
