'Lookout Citadel Server' blocks database access over TCP/IP
We are using the actual NI-DAQmx-driver for DAQ-hardware.
After installation, our hosted database 'FileMaker' (an older version) does not work again: the initialization over TCP/IP fails.
If we disable the 'Lookout Citadel Server'-service, all works correct, again.
*Is this an known problem?
*What's the function of the 'Lookout Citadel Server'?
Thanks for your help.
(3,837 Views)
Hi Hansman,
thank you for your post.
Unfortunately, this is a little less information for me to find a relation between DAQmx and your problem.
Can you send a little more information or even screenshots?
Abduelkerim
Sales
NI Germany
(3,825 Views)
Hi Abduelkerim
We are using  Claris FileMaker Pro 3.0 .
We hope, that with the newest  FileMaker 12  the problem will be solved.
If there would be a problem too with FileMaker 12, I will contact you again.
Best regards
Hansman
(3,818 Views)
Hi Hansman,
Since I do not now anything about Claris FileMaker I don't know why there should be any problem.
Please hold me up to date.
Abduelkerim
Sales
NI Germany
(3,816 Views)
