cancelar
Mostrando resultados para
Pesquisar então
Você quer dizer:
Linux NI-DAQmx Base 64-bit application support?
Resolvido!
Ir para a solução
I'm running Scientific Linux 6.x developing custom applications that utilize data transmitted/acquired via PCI-6259 cards. Recently the application is approaching the 3.5 or so gig RAM limit with 32 bit applications. We're using NI-DAQmx Base 3.6.0 installed in fall of 2012 so I figured maybe there was a newer version of the driver that supported 64-bit applications. It appears that version 15 (the most recent version for Linux) still does not. I noticed that NI-DAQmx 16.1 for Windows does support 64-bit applications, though. Does anyone on here know the time-table for release of a driver with 64-bit application compatibility for Linux?
Mensagem 1 de 3
3.874Exibições
Solução
Aceita por james.orr
Hi James,
NI-DAQmx Base 15.0 for Linux did add 64-bit usermode support for LabVIEW and C applications. It appears that the readme and download page weren't fully updated to reflect that :-S
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
Mensagem 2 de 3
3.848Exibições
Woo! Best news I've gotten all day. Thanks Joe!
Mensagem 3 de 3
3.845Exibições
