Linux Drivers for PCI/PCIe/USB
Hi -
I develop a real-time linux based (using Ubuntu and Scientific Linux) platform that uses NI's Multifunction DAQs (E and M series). Up until now we have used open source driver sets such as COMEDI (from RTAI) and Analogy (from Xenomai) to interface with these cards, however the newer X-series cards are not being supported by either of these - and development seems to be at a halt.
I was wondering if NI provides a linux-based driver set for these cards. If so, is there a list of cards it supports?
Thanks.
(7,112 Views)
Hello yapatel.
We always try to recomend the use of DAQmx, since it is the officially supported driver. Probably you will find this links useful.
What Linux Distributions Do National Instruments Drivers and Software Support?
http://digital.ni.com/public.nsf/allkb/4857A755082E9E228625778900709661?OpenDocument
Drivers Needed to Use National Instruments Hardware on Linux
http://digital.ni.com/public.nsf/allkb/DA11427DB450FDCB86256257005717D0?OpenDocument
Fabián M.
Internal Sales Engineer
(7,081 Views)
Accepted by yapatel
yapatel wrote:
Hi -
Thanks.
If you're considering X Series devices, the only Linux support NI offers is through a source-based driver, the MHDDK [1].
In addition to the source code, the DDK also includes documentation on the registers, bit-fields, and theory of operation for the device's capabilities.
The DDK demonstrates how you would program a DAQ device on any OS. Note that this goal is different than how you would create a DAQ driver for any OS. In other words, the DDK is intended to demonstrate which registers and bit-fields to program and in which order they need to be programmed so that they can properly control the hardware. The DDK is not a reference architecture for driver and kernel programming, but more like executable documentation.
[1] Measurement Hardware Driver Development Kit (MHDDK) Frequently Asked Questions
https://www.ni.com/en/support/documentation/supplemental/18/measurement-hardware-driver-development-...
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(7,077 Views)
