Legacy AO-10 Calibration Routine
We are using a legacy AO-10 card in an extended chassis and we are now seeing a 100mV zero offset.  If i plug the card in the non extended backplane there is no offset. I would like to try the calibration routine to see if we can adjust out the offset.  Is there an VB example or an executible of the routine available?  Running NIDAQ 4.8.0 on windows 95.
(4,100 Views)
Have you looked at the calibration procedure in the manual for this device?
https://www.ni.com/docs/en-US/bundle/320379/resource/320379.pdf
(4,075 Views)
Thanks for the response.
Yes I did.  I wanted to check to see if there was VB code or even an executible already developed before undertaking building one.  Since this card is so old I would bet someone already produced one. It looks like the VB sample code that comes with the NIDAQ driver is VB 1.0.  I think that there maybe an old Labview VI that allows calibration of this card.
(4,071 Views)
I have looked for anything that might accomplish this. I haven't been able to find anything searching the web or asking around internally here at NI. Hopefully someone else on the forums has something that will work for you! Good luck!
(4,038 Views)
