Hi Igor,
To understand the situation better, what kind of device are you using? Is the program modified from the "Write Digital Port.vi"? If so, this program should output the value specified by the user until the value is changed, since the Write VI is inside a while loop and continually reads the data in the control. I hope this will help.
Lesley
