02-01-2007 03:33 PM
02-02-2007
06:45 PM
- last edited on
07-15-2025
11:19 AM
by
Content Cleaner
Hello Tony,
The behavior you described does sound very strange. Have you tried uninstalling NI-DAQmx 8.0.1 and then reinstalling NI-DAQmx 8.3 and then building your application? That would be my recommendation based on the information you provided. If you still have issues, I would suggest that you uninstall both versions and install NI-DAQmx 8.3.1.
I also have a couple questions to clarify the behavior you are seeing. What version of the NI-DAQmx driver did you use to develop your application? How have you installed the different versions of NI-DAQmx? Are they both on a driver CD that you have? Does the error you are seeing include any error number or error message? Any more information you could provide would be helpful.
02-03-2007 04:31 PM
02-06-2007 03:43 PM
DAQmx 8.01 was not installed on the computer. Actually I upgraded from labview 8.2 Pro to labview 8.2 Developer Suite and uninstalled all NI S/W before the upgrade. I did purchase a USB-6009 that came with DAQmx 8.01 CD which I used to install VI logger. My application uses DAQmx 8.3 functions.
I did found that if I used Runtime 5 setup on the installation of DAQmx 8.3 the error doesn't show up and I'm able to get the H/W to work from the installer.
Thanks for the reply.
