Multifunction DAQ
LabView code generation failure
Hi!
I've just bought a NiDaq 6008, and I have the same problem:
"LabVIEW Code Generation failed to execute. This may occur if the code gen engine is not properly installed, or if you are using a LabVIEW version under development." 😞
If someone has an idea to solve this problem, please help me!
Message 11 of 15
(3,622 Views)
First thing that you should try to do is reinstalling DAQmx driver.
You can find it on www.ni.com/drivers
Kind regards,
Ion R.
Message 12 of 15
(3,618 Views)
It appears that LabView2011 can generate some trouble on systems with CPU without SSE2. If you have such machine, you can try LabView2010.
I did not try this solution yet, so I do not know if it helps.
Please chceck the following thread: http://forums.ni.com/t5/LabVIEW/VI-Properties-dialog-is-slow/m-p/1882209
Message 13 of 15
(3,609 Views)
why use daq assistant rather than init/read/close?
Message 14 of 15
(3,601 Views)
Hi again!!!
I solved mi problem ;). I bought my NIDAQ 6008 some days ago, it included a Dvd of NI-DAQmx 9.1.7 and a Dvd of LabVIEW 2011. It seems that them both were not compatible, since the icon of "DAQ Assist" didn't appeared (first, I had the problem in my previous post).
So I uninstalled everything related to National Instruments (LabVIEW 2009, 2010, 2011, NI-DAQmx) of my computer (Windows XP SP3) and reinstalled LabVIEW 2010, LabVIEW2011 and NI-DAQmx 9.1.7, and I still had the same problem.
BUT!!! When opening LabVIEW 2010, a blue window popped up automatically and it said that I could install something like patches or updates (I really don't know exactly what they are, patches I guess) for NI-DAQmx (in total it was about 600 MB), so I did it. And the problem has gone. My LabVIEW 2010 now works perfect with my NIDAQ and with all the modules.
If I wanted to work with LabVIEW 2011, I would have to update the latest version for NI-DAQmx (it's in this web). But, I feel comfortable working with version 2010. 🙂
In general, I guess the main problem is that the version of NI-DAQmx and LabVIEW aren't compatible in some cases.
I put LabVIEW 2010 and LabVIEW 2011 windows for you to see the comparation.
I hope it helps.
Message 15 of 15
(3,589 Views)
