Multifunction DAQ
LabVIEW FPGA Timing Issue.
I am using a USB-7845R to create a step function that when my FPGA receives a "high" pulse from Connector1/DIO6 it steps up by some value "Sync Step Size" and when a "high" pulse from Connector1/DIO7 is received it resets the value to the initial value of 0.
When measuring on my oscilloscope I notice that the timing is off where I see pulses from Connector1/DIO6 but it is not stepping up in sync with the pulse. Is there something off about the timing structure that I am using. For reference the pulses from the camera attached to DIO6 occur every 10 us and the pulses from DIO7 occur 10 us * # vertical rows of my field of view.
Thank you in advance for suggestions!
(952 Views)
Your AO node slows down the entire speed of the while loop, capping the loop at 1us since the AO has a maximum update rate of 1MS/s.
I would recommend you move the AO node out to a separate while loop. Then change the while loop with the digital I/O to a timed loop to make use of the 40MHz clock.
https://tmesystems.net/
(914 Views)
