Multifunction DAQ
Is the dynamic range on the DAQCard 516 adjustable to any other range besides plus/minus 5 volts?
Is the dynamic range on the PCMCIA DAQCard 516 adjustable to any other range besides plus/minus 5 volts?
I realize this is a simple question, but I have reviewed the DAQCard 516 spec sheet and it only indicates the plus/minus 5 volts.  I am trying to decipher what effect the Measurement and Automation Explorer has when adjusting the dynamic range using virtual channels.  For this particular card, I am using LabVIEW 5.1.
I also use a PCI-6052E card with LabVIEW 7.1.  I have a number of adjustable dynamic ranges with this card.  They range from plus/minus 0.05, 0.1, 0.2, etc.  I don't believe I have the same adjustability with the DAQCard 516.
Any clarification would be greatly appreciated.
(2,867 Views)
Your understanding is correct.
This card does not have selectable AI signal ranges.
(2,857 Views)
