在 12-12-2011 12:03 PM
The simulated device setup is this:
9174 cDAQ chassis (cDAQ1)
- 9215 (cDAQ1Mod1) (analog in)
- 9401 (cDAQ1Mod2) (digital i/o)
With one digital line (e.g., line 4), I create a single pulse
where the caret indicates the short, single pulse.
Is it possible to use a digital line (e.g., line 0) in to measure this in the simulated device by using some kind of direct/indirect routing? If so, how would one set up the digital input read task to essentially read internally the output on line 4?
Thanks.
已解決! 轉到解決方案。
在 12-12-2011 08:59 PM
