Multifunction DAQ
Intermittent vhdci connection problem
Has anyone had problems with the VHDCI connectors on the M-series DAQ boards? I am getting intermittent connections on both systems that I have used the boards on (PCI-6259). Re-seating the cables at the board solves the problem for a while, but it reappears in a day or two. Any suggestions?
(2,907 Views)
Hello Tnsguy. I haven't heard of any issues with those connectors. Are you using the SHC68-68-EPM cable? Make sure you have the cable screwed in all of the way. Check the pins on the connector and cable. Are any of them bent? Please let me know if you have any questions. Have a great day!
Marni S.
(2,891 Views)
