Multifunction DAQ
Intermediate vi's
Where are the intermediate vi's ( AI Config.vi, AO Config.vi etc.) in LABView 7 ??? I don't have the Data Aquisition Palette/Analog In or Analog Out in LV 7 like I did in LV 6.1
(2,574 Views)
Greetings,
In LabVIEW 7.0, the Traditional NI-DAQ functions should be available in the following location:
Functions >> All Functions >> NI Measurements >> Data Acquisition
If this palette does not exist, most likely, you have not installed Traditional NI-DAQ support for LabVIEW 7.0. To install this support, you should navigate to the entry for the Traditional NI-DAQ installation in Add or Remove Programs (Start >> Settings >> Control Panel >> Add or Remove Programs >> National Instruments Software) and select Change/Modify.
Good luck with your application.
Spencer S.
(2,573 Views)
