Input / output synchronization
I need your help to synchronize a digital output with a digital input with LabVIEW 8.2.
  • I have a NI6289 PCI board.
  • A digital output will behave as the green signal on the following diagram.
  • I need to generate the blue signal on a digital output, knowing a rising edge of this signal must be generated a defined time after a rising edge on the green signal (dig. input) (e.g. :  here 15ms). Moreover, a falling edge must be generated a defined time after the same rising edge of the digital input (e.g. : here 35ms).
  • The digital output must be generated continuously. Indeed, the digital output will be repeated continuously, and the digital output must continuously behave as the following logical diagram.
  • The accuracy needed is one millisecond.
  • The green signal (input) frequency is approximately 2Hz, and can vary (< 2Hz).
I assume I need to use the internal timers, but I did not succeed in doing something correct.
Thanks for your help !
(3,561 Views)
Nobody has an answer to my question ?
(3,536 Views)
Accepted by arnaud_QC
The is an example named Gen Dig Pulse-Retriggerable.vi that ships with LV.  It should be very close to what you want to do.
(3,526 Views)
Thanks Centerbolt,
that's exactly what I wanted. I didn't see this example before (even though I tried a lot of them) !
Thanks for you help, I needed it !
(3,506 Views)
