Multifunction DAQ
IOTech DaqBoard 2000 with DBK 43 not available in MAX
I cannot install the DaqBoard in Labview. In WindowsXP the device is properly installed. Reinstalling and updating did not solve the problem. If you don't know, how can I install the hardware in LABView by myself (without assistants)? Or in which folder does LABView search for devices? What information should be in this folder?
(3,074 Views)
Ok, the issue with MAX is solved, but how can I check if the driver for LABView is properly installed (--> my question about the folders)?
(3,074 Views)
Hi grafzahl,
is your board recognized in max now?
(3,074 Views)
no, it isn't. But thats ok, because it is not a National Instruments card. I didn't get it to read the forum, BEFORE posting a question. I found the answer there.
My only question remaining is that I'd like to know if I installed the drivers properly. Is there a place in LABView, where this information can be found? Or is there perhaps a folder, where the driver (or something else) should be?
Thank you.
(3,074 Views)
