Multifunction DAQ
I have an AI-16E-4; Error device doesn't support Dig_Trigger_Config
I have an AI-16E-4, which is a 6062E.  I'm trying to configure a digital trigger - but when I make the call to DIG_Trigger_Config, I get error -10403 "Action is inappropriate for the device". Is that true? I thought that this card had digital I/O and triggering?
(2,628 Views)
Hi M_caldon,
The card you have is actually a 6041E. This card does support analog triggering through the DIG_Trigger_Config command in Traditional DAQ. Here is the product manual that confirms this.
This was an issue with older versions of the driver, are you using the newest version of the Traditional DAQ driver?
Also, what input parameters are you passing to the DIG_Trigger_config funtion?
Abhinav T.
Applications Engineer
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(2,613 Views)
