09-06-2006 01:17 PM
09-07-2006 11:31 AM
What was the resolution and voltage range of the TXI board? The 6009 has 13 or 14 bits of resolution depending on whether single ended or differential mode is used. Could be the 6009 has more resolution and is thus detecting noise that the TXI could not resolve? The 6009 also has low input impedance (not usually a good thing) when compared traditional DAQ cards- only 144Kohm. Could this be affecting your photodiode signals? What amplitutude range are the photodiode signals and have to set teh 6009 to the proper range?
Regarding cross talk- are your analog signal wires routed away from other noisy electronics- pumps, valves, and all other wiring? Have you tried differential mode on the analog inputs on the 6009? Are you analog signal wires shielded? Proper grounding techniques followed?
Sorry for all the questions, troubleshooting noise issues in someone else' system remotely can turn into a can of worms
09-21-2006 08:46 AM
I have not completely worked out my noise issues, and have some related questions.
1) I want to be sure that I have the system correctly grounded: I have 3 analog signals coming from a circuit board (our analog board; all signals are tied to the same ground). In RSE mode, I have the ground from the analog board connected to the left-most ground slot on the analog side of the USB-6009. I then have the signals connected to AI0, AI1, and AI2. Is this sufficient or do I need a ground for each signal?
2) I have also added to my system a YSI thermistor. I am measuring the V(in) and V(out) from the thermistor at AI6 and AI7 without an additional ground (the V(in) signal comes from a circuit board (our power board) which is grounded to the analog board which is grounded to the USB-6009 as mentioned above). Do I need to ground these inputs separately? Are all the ground slots on the USB-6009 connected? If not, it is unclear to me which ground belongs to which signal input.
3) If I were to use differential mode, would I wire each signal plus the ground to the + and - terminals? e.g. would I wire signal 1 to AI0+ and ground to AI0-? Then what is the purpose of the ground slots?
4) If I were to use differential mode for my first three analog signals, could I use RSE mode for my thermistor V(in) and V(out)?
Thanks, Sorry for all the questions
09-22-2006 04:28 PM
I would not use RSE mode if your analog signals are considered a grounded source (which it seems like they are). You could be introducing ground loops. For more information, please check out the tutorial Field Wiring and Noise Consideration for Analog Signals.
The inputs do not need grounded separately. All analog grounds are connected inside the USB-6009.
Yes. The ground connections are for the RSE measurement configurations.
Yes. You would use all of your analog input channels - 6 for the three analog signals and the remaining two for each of the thermistor measurements.
Hope this information helps!
Laura
09-22-2006 04:47 PM
Laura:
Can you mix differential and RSE configuations on the 6009? I was under the impression it had to set all channels to one or the other.
09-22-2006 05:27 PM
09-27-2006 10:01 AM
09-28-2006 12:53 PM
Hi mtngirl,
It seems to me like you could be experiencing some sort of grounding issue. When you measure the power supply using AI 3 and AI 4 in RSE mode, are all other wires disconnected? If not, how are the rest of the channels connect to the USB-6009? Can you ground AI 3 and AI 4 and see what happens? Do you experience any oscillating?
Answering these questions will help us figure out what is happening.
Laura
09-28-2006 01:05 PM
09-29-2006 03:50 PM
Hello mtngirl,
If you can take that same voltage and apply it in RSE configuration to another channel and it reads correctly, but incorrectly on channel 3 or 4, it seems that those two channels could be damaged. You should contact our technical support department to determine if you should send the device in for repair.
Laura
