How to use DAQmx Read to measure multiple analog channels
You posted to the wrong board. I have asked the moderator to move this thread from the LabVIEW board.
Message 11 of 16
(6,956 Views)
I have a chassis and NI module which are cDAQ-9171 and NI 9205. (I use Labview 11.0 version)
I try to get two analog input values from different two analog chanels of NI 9205. Unfortunatelly, it is dislayed the same error. (Screenshot is in attachments).
Also, i send my project file in attachments to you for making clear everything.
Thank you in advance for your interest
Serbay Özkan
Message 12 of 16
(5,686 Views)
Dear KoenR94,
I have a very similar problem. I read from two channels but I wish to have two different graph indicators for each channel. However my daqmx only gives me 1 output data that I can plot. Any suggestions?
vi. attached
Message 13 of 16
(4,003 Views)
I would use the split function to get both signals.
Message 14 of 16
(1,754 Views)
Hey, did you get the solution? I am also finding similar problem, reading multiple AIs is giving error using python.
Message 15 of 16
(1,533 Views)
You need to put all the channels into a single task and not create a separate task for each AI channel.
Santhosh
Soliton Technologies
Only two ways to appreciate someone who spent their free time to reply/answer your question - give them Kudos or mark their reply as the answer/solution
Message 16 of 16
(1,525 Views)
