10-06-2005 08:49 PM
10-07-2005 10:31 AM
10-07-2005
10:57 AM
- last edited on
07-15-2025
11:05 AM
by
Content Cleaner
Hi All-
John is correct- the NI-DAQmx 7.5 driver supports the USB-6008/9 and should be configured using the instructions in this KB.
The driver doesn't support Visual Designer directly, but you should be able to call into the NI-DAQmx .dll. NI-DAQmx natively supports C++ and VB 6.0, .NET, LabVIEW 7.x, and CVI 7.x. If you choose to call the .dll from your ADE the NI-DAQmx C Reference manual should be helpful and will be installed at Start>>Programs>>National Instruments>>NI-DAQ.
Thanks-
