Multifunction DAQ
Error Code -200220
I'm developing an independant application for a USB-6009. I get -200220 from the DAQmxResetDevice function. Does anyone know where I can find a list of these errors?
(4,009 Views)
tommysaurus,
Here's the error description:
Error -200220 occurred at an unidentified location
Possible reason(s):
Device identifier is invalid.
In order to get this info yourself, I believe you can use the DAQmxGetErrorString function.  It's explained quite nicely in the NI-DAQmx C Reference help.  But basically it should take an error code, and pass back a string description.
Hope this helps,
Dan
(4,007 Views)
Thanks, Dan
(4,002 Views)
Just wanted to add one other function you can use to get further information is DAQmxGetExtendedErrorInfo.  This may get you a bit more speciffic information on your error.
Dan
(4,002 Views)
It doesn't take an error code and return information (I wish it did). You call it right after an error has occurred and you can get the error information.
John Weeks
WaveMetrics, Inc.
Phone (503) 620-3001
Fax (503) 620-6754
www.wavemetrics.com
(3,995 Views)
