Multifunction DAQ
How to query DAQmx task state in LabVIEW?
I do not have a trigger for my application. I just have Start - Read - Stop (All as action Engines) happen in a sequence in a case structure before it moves on and returns back to acquire 1000 samples again.
It is a continuous 'FINITE' sample acquisition. I will try to get a snippet posted soon.
Message 11 of 21
(4,097 Views)
Here is the vi I am using for tesing the concept. It is a modified version of the example for finite input.
Without using control task and commit - Loop - 215-220ms
With control task and commit - Loop - 170-175ms
Additional Info:
The funny thing is there is a difference between simulated HW and actual HW. The above timing holds when I have my sensors connect to the AI module
When I use simulated HW, these are the times.
Without using control task and commit - Loop - 145-150ms
With control task and commit - Loop - 105-110ms    (This time would ideal for my application but I don't know why there is an additional 70ms)
Message 12 of 21
(4,080 Views)
Thanks, but I'm still running LV 2013 and can't open the vi you posted.  Can you save back to 2013 or post a screenshot?
-Kevin P
Message 13 of 21
(4,075 Views)
You should be able to open this in LV2013 now.
Thanks for your support!
Message 14 of 21
(4,072 Views)
At 10 kHz sampling, reading 1000 samples at a time, I regularly get loop times of 101-103 msec.
Using the "commit" first seemed to give me more 101's while skipping it seemed to give more 103's, but there really wasn't a lot of difference.
I tried both a PCI M-series card and a PCIe X-series card.  I put some sequencing in your loop to make sure the tick count query happens at the end of the loop.  I tried both finite and continuous sampling.   None of those changes mattered in an obvious way.  There were only a few extra msec consumed by doing a stop and restart.  Never anything close to the 75 or 100 msec that you described.
Wondering if you're using a USB or cDAQ board b/c my PCI and PCIe multifunction boards both support much lower overhead looping.  Attached is a modified version that measures only the stop/restart time with a higher resolution clock.   I kept seeing about 1.1 msec with the commit, 1.5 msec without.
-Kevin P
Message 15 of 21
(4,057 Views)
Thank you for the response. I will try your modified version.
I am using a cDAQ 9178 chassis with 4 modules in it (NI 9213, NI 9229, NI 9227 and NI 9375)
RESULTS:
Without Commit - I see config time - 0.133xxx to 0.150xxx (between 133ms and 150ms mostly around 133ms)
With Commit - I see config time - 0.071xxx to 0.073xxx (between 71ms and 73ms)
I am still surprised with such high latency in transfer of data from DAQ buffer to databus. I thought the cDAQ chassis was quite robust; obviously not quite the cRIO but, I would have expected upto 25ms latency. 60-75 seems quite large.
Message 16 of 21
(4,054 Views)
I happened to be on a cDAQ for other stuff this afternoon so I tried out that last vi.  I saw about 40 msec with the "commit", more like 85-90 msec without.
This is a 9178 USB cDAQ chassis and a 9205 module, on the same PC I used with the plugin boards previously.  Just an FYI to confirm what you're seeing.
-Kevin P
Message 17 of 21
(4,029 Views)
-Kevin P
Thank you so much for confirming what I see. I wonder if USB 3.0 would reduce that time. But, for now, I am going to park this issue.
Vijay
Message 18 of 21
(4,010 Views)
Disclaimer: I know this is an old post, I just don't know if I should create a new one and reference this one, since I believe this technically answers the post's question and I wanted to share my solution. (Please advice)
I actually had this question myself a while ago. I was also pretty curious as to why there was a way to set states through the API but no explicit get method for it.
Like OP mentioned, there's actually a function in the nilvaiu.dll called:
int32_t DAQGetTaskState();
Which is pretty self explanatory, the only issue being that the function parameters/signature is unknown and since it is undocumented, they didn't know how to use it.
A bit of background: I was taking a look at the C API of DAQmx and looked at other function calls in the LabVIEW DAQmx API and just tried setting something that would probably look like it/match existing usage of other functions. (At least according to me)
This is what ended up working for me:
int32_t DAQGetTaskState(uintptr_t taskID, int32_t *mode, int32_t incomingStatus, LStrHandle extendedErrorInfo);
I just changed mode to a pointer for reading like in other calls/similar functions. (Pretty much just a guess/luck)
I'm sharing the SubVI here:
A few notes/info:
  • I've tested the VI and it works. I've managed to query the state of the tasks I've run. However, I've only tested this in a single cDAQ chassis (9178) and a digital output module (9472). There's no guarantee it would work in other systems, which brings me to the next note.
  • This is an undocumented function of DAQmx. So there's obviously no official support as far as I can guess, so I probably would not rely on it. I'm using it for educational purposes.
  • The mode ring output includes 2 other values that appear in the C API in "DAQmxTaskControl", so not just the 5 states in the action input of DAQmx Control Task.vi
(I'm assuming this really is undocumented so if it turns out it actually is documented and I didn't find it, then I goofed. I'm still a noob overall)
Message 19 of 21
(2,839 Views)
Ok. So somehow I goofed in a really dumb way.
So I tested with more hardware and realized that the constants I'm using are wrong since those are for setting the states. There is no state such as un-reserved. The actual states as described in the documentation are the following:
  • Unverified
  • Verified
  • Reserved
  • Commited
  • Running
I've tested again and NOW I'm seeing consistent behavior. (I still wouldn't rely on it though since its undocumented)
I'm editing the SubVIs above.
I've also attached a small example/test for reference below:
This were my results:
Edit: Ok. So I guess I can't edit the previous post. I've attached the correct one here:
Edit 2: This is embarrassing. Updated documentation.
Message 20 of 21
(2,803 Views)
