Multifunction DAQ
How to measure multiple analog input at the same time.
I tried to make a VI that controls a motor with two buttons. If I press the buttons, the VI took the analog signal from the buttons and  the motor rotates. Each button deals with different direction - counterclockwise and clockwise.
I need to input both signal in the VI at the same time, but I can't. If I run the VI, the VI takes only one signal randomly. I want to know what the problems are, and How to solve them. Please help me.
(8,950 Views)
Accepted by slssokfk
You need to use a single task for both channels.  See if this helps.
(8,934 Views)
So glad to find this post, I was going to post the same question, I know how to use it with NI Max but was hoping an easier way like this. Thanks!
-ncm
(8,827 Views)
