How to avoid multiple single clicks in Event Structures
I am using event structures in my programe and I want to avoid the case when user mistakenly presses the single click button multiple times, because if the user presses the single click button multiple times the event is registered mutliple times and the funtion inside "Value Change" gets repeated multiple times as well. I want to avoid this scenario.
Can anyone please help in this regard.
(4,448 Views)
Accepted by topic author shami81
Well, there is the "Lock Front Panel Until Event Case Completes".  You could also disable the button until a timeout happens.  Another option if you have LabVIEW 2013 or later is to limit the number of event cases (option just below the locking of the front panel in the Edit Events dialog).
(4,446 Views)
Thanks a lot for for your time. I implemented the first solution and it worked perfectly fine.
(4,415 Views)
