How start and stop a task with C# ?
Guys,
I need a help. I'm trying reproduce a task created using Meansument & Automation Explorer. The task is very simple create a digital output channel and send values 0 or 1 to enable and disable a relay in my DAQmx board.
Alexandre A.
(6,136 Views)
Hello Alexandre,
     C:\Program Files\National Instruments\NI-DAQ\Examples\VisualC
    When you install DAQmx you install examples for Visual C too. Maybe you
adapte to C#.
Abel
NI Brazil
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(6,115 Views)
Duplicated forum
http://forums.ni.com/ni/board/message?board.id=250&message.id=44387
Abel Souza
(6,096 Views)
Accepted by Aalbuquerque
I found the solution, add a new item in solution using add new item choose ni component and set the configurations like a kind of task you need. The item will create a class to the your task, this class has all events to start and stop a task and you can add your new methods if necessary.
Thanks all.
Alexandre Albuquerque
(6,093 Views)
